searching a date range
2100
02-22-2012 06:32 AM
JamesArmstrong
I am using the enhance serch widget from Robert.  Outstanding!!
Is there a way to include a search by range - such as  a date or price range?  Such are sales date for parcels.
I suspect that this may be something that needs to be edited in the source code, but thought that there may be a query statement that could also be used.
Thanks in advance
James
by Anonymous User
Not applicable
Original User: rscheitlin
James,
   OK than try this:
<expression alias="Date Search"                            textsearchlabel="Search by Typing Full SQL  example:[ SALE_DATE &gt;= '04/03/2011' AND SALE_DATE &lt;= '07/01/2011'  ]...">[value]</expression>
by Anonymous User
Not applicable
James,
   It can be done in a Query but..... As multiple field queries are not supported in the eSearch expressions in the same way that others are you have to do a workaround.
The Query would look like this assuming you are using SDE and not a file GDB:
SALE_DATE >= '2010-03-03 00:00:00' AND SALE_DATE <= '2012-03-03 00:00:00'
You would have to manually type this in the TextBox of the eSearchWidget when you choose this expression in the dropdown:
<expression alias="Open SQL" textsearchlabel="Search by Typing Full SQL example:[ SALE_DATE >= '2010-03-03 00:00:00' AND SALE_DATE <= '2012-03-03 00:00:00' ]...">[value]</expression>
JamesArmstrong
the actual query work great, though one issue.  This is the code I put into the xml.
                           textsearchlabel="Search by Typing Full SQL example:[ SALE_DATE >= '04/03/2011' AND SALE_DATE <= '07/01/2011' ]...">[value]</expression>
as you can see I did change the data format a bit, but it does seem to work (I am using a SDE database) when I use the SALE_DATE >= '04/03/2011' AND SALE_DATE <= '07/01/2011' in the entry box.
This issue is that there is a parseing error if the SALE_DATE >= '04/03/2011' AND SALE_DATE <= '07/01/2011' is left in as the example string.  If part of it is removed, there is no problem.  I thought it may have something to do with the quotation marks around the date, but when removed, the same parsing erro happens.
JAMES
by Anonymous User
Not applicable
James,
   Are you using version 2.5.1.3? If not that that is the problem.
JamesArmstrong
yes  I am using the lates version.
I now dont think the issue is with the single quottons marks.  Instead, it seems the issue centers on the <= sign.  I have removed it, or used just the = sign and even the > and the parsing error is not thrown.  With that sign (or even =<) the parsing error is thrown.
James
by Anonymous User
Not applicable
James,
   OK than try this:
