Export release build error in Flex Builder 3
964
12-06-2011 11:57 AM
BrianDonaldson
I am using Flex Viewer 1.3 and the debug version runs fine, but when I export a release build it
gives me
Encountered errors or warnings while building project style.css.
style.css: An internal build error has occurred. Right-click for more information.
and I have gotten this error as well: VerifyError: Error #1053: Illegal override of FlexModuleFactory in mx.core.FlexModuleFactory.
I am using SDK 3.4, but I have older SDK's installed.  SDK 3.4 is set as the one used.  Many times for debug I need to re compile just the style.css.
In the css file I am using an embedded font.  I do not know if this is the issue or not.
Any ideas would be appreciated.
Brian
RobertScheitlin__GISP
Brian,
   I can't recall exactly but I seem to remember there being this issue with one of the 3.x SDKs. I know that the 3.2 SDK was a good stable SDK for the SFV 1.3.
ZhujingXia
Brian,
I got the same error when I do the 'export release build'. Did you figure it out? Some of my projects have this issue but others are fine.
Zhujing
