Scroll option for Robert's Identify widget?
1845
17
11-01-2011 06:56 AM
SheriNorton
Occasional Contributor II
Is there a way to enable a vertical scroll bar in the Results in Robert's Identify widget? My mouse has a middle "scroll" button, but other users many not have that capability. The additional results are cut off without a control to let the user see all the contents of the Results.
Attached is an example of cut off records...
GIS_TechEngineering
Sheri,
   In the lower right hand corner of the search results ther is a triangular symbol. Grab that symbol with your mouse and enlarge the widget to the right and down. A scroll bar should automatically appear.
Hope this helps,
Billy
RobertScheitlin__GISP
Sheri,
   Are you saying that you never get the scroll bar or did this just happen once or twice?
SheriNorton
Hi Robert,
I've never had the scroll option. The only way to move down the list of results is to use my middle scroll on my mouse.
Sheri,
   I have never seen this widget do that... Have you done anything to it like explicitly set the width and height, maybe in the main config.xml?
SheriNorton
Hi Robert,
I've attached a screen shot of the Main Config settings - do I need to indicate usage of scroll bars here or in another section?
Sheri,
   No there is nothing you have to do to get the scroll bar I was just trying to see if you had done something that might be causing the issue. I'm really at a loss here. Have you downloaded the latest version of Adobe Flash Player?
SheriNorton
Hi Robert,
I just downloaded the latest Flash Player, cleared the Rest Cache, but still do not see scrollbars. I've tested the Flex Viewer on both the server and my desktop, no luck.
Sheri,
   If you use mine live site do you get scroll bars?
http://gis.calhouncounty.org/FlexViewer2.4/index.html?config=config-identify.xml
SheriNorton
Yes! For both my server and desktop there are scrollbars in the Identify results. At least that narrows down the problem to something in my Viewer...
