Route Widget pdf
758
10-22-2012 11:16 AM
PatriciaMoehring
Does anyone out there know how to change the size of the map on the pdf?  Right now if I select the map to print with the route, the map shows up as a portion of the page but if I wanted the map to take up the whole page -- is there a place I can reset that?  Or if I just wanted the route to show up on the map without the directions -- is there a way that I can make that a selectable choice?
I've tried using the advanced printing option but the advanced printing will not print the route on the map.
Any ideas or suggestions or other ideas out there?
Patricia
RobertScheitlin__GISP
Patricia,
   None of those things you are wanting to do are configurable...
