Route Widget for 3.2 and 3.3
860
6
05-15-2013 12:34 PM
Sung-JunKim
Hello,
I've downloaded Robert's Route Widget 3.2 and 3.3 and deployed using our own network analysis service, but got an error that says
unable to complete operation...Clear and start again or add another valid stop. I tested both 3.2 and 3.3 and got the same result. Does anybody have any solution to solve or workaround the issue using your own network analysis service?
This is a great widget and needs to be fully utilized. Thanks, Sung-Jun
RobertScheitlin__GISP
Sung-Jun,
   I developed this widget using esri NAServer and it is only been tested again that server. Is your service public? There are MANY things that you could have configured differently in your NAServer that could cause an issue. I really only garuntee this widget to work with esris service. Also have you tried esris OTB route widget?
Sung-JunKim
Robert,
I published two network analaysis services if you would like to try to see what causes an error.  These services are from 10.0 server.
1.  Network dataset is based on NAD1983 UTM 17N
http://infoweb01.dhec.sc.gov/ArcGIS/rest/services/Network/NetworkDS_SC_utm17/NAServer/Route
2.  Network dataset based on WGS 1984 GC
http://infoweb01.dhec.sc.gov/ArcGIS/rest/services/Network/NetworkAnalysisSC_GC/NAServer/Route
I will appreciate your help.
Sung-Jun
Sung-Jun,
   Your route services do not support a couple of things that are hard coded into the widget.
restrictionAttributes
Avoid Private Roads
Avoid Ferries
useHierarchy = true;
If you have access to Flash Builder these can easily be changed and then your service works fine in the widget.
BjornSvensson
Sung-Jun, I'm curious if you tried the Directions widgets?  It seems to work fine with your service...
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Directions_widget/01m3000000570...
Sung-JunKim
Sung-Jun,
Avoid Private Roads
Avoid Ferries
Robert,
It works like a charm.  I truly appreciate your help.  I may try ESRI's route widget as well.
Cheers,
Sung-jun
Sun-Jun,
   Great, gald you got it working.
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow these steps as shown in the below graphic:
