Reverse the order of display of basemaps
2741
6
02-08-2012 09:17 AM
LefterisKoumis
In another forum question (http://forums.arcgis.com/threads/49443-Basemap-own-and-esri-can-be-posted-together) it was determined that the easier way to display your own basemap along the esri basemaps is to place your basemap last, so that the LODs of the esri basemaps are set first. However, for display purposes on the map switcher, is there any way to reverse the way that the basemaps are displayed to show their labels in reverse order? To be clear, I am asking not to reverse the order of the basemaps in the config.xml file but the basemap labels in map switcher display, so my basemap is shown on left side of it.
Thank you.
RobertScheitlin__GISP
Lefteris,
  So do you see anything displayed in your problems window in Flash Builder? I tested this on my end and it works fine...
Lefteris,
  Do you have the ability to change code in the Viewer?
LefterisKoumis
Lefteris,
Yes I do. I loaded up the source code of flexviewer in the adobe flash builder.
Thanks.
Lefteris,
   Than the cahnge is a simple as this, In the MapSwitcherWidget.mxml change this function as indicated below:
            private function initBasemapButtonBar():void
                basemapList = new ArrayList();
                var labels:Array = [];
                for each (var basemap:Object in configData.basemaps.reverse())
                    var label:String = basemap.label;
                    if (labels.indexOf(label) == -1) // avoid duplicates using the labels
                        labels.push(label);
                        basemapList.addItem(basemap);
                if (basemapList.length <= 1)
                    this.currentState = "noBasemaps";
                else
                    setBasemapButtonBarIndexToTopmostVisibleBasemap();
Don't forget to click the Mark as answer check and to click the top arrow (promote) as shown below:
LefterisKoumis
Lefteris,
                        labels.push(label);
                else
I did just that and recompiled the website and now the map switcher is not displayed at all.
Lefteris,
LefterisKoumis
Lefteris,
THANK YOU. Yes, it does work! Sorry. I changed the source code of other mxml earlier trying to increase the width of the icon of only one widget and apparently the map switcher dissapeared as well. I will post the question for the icon width in another post. Thank you again.
