Related Records not showing in Attribute Table
2346
6
06-17-2013 05:08 AM
EddieArnold
I've managed to get my related records to show in the popups and the enhanced search widget without any problems. However, the Attribute Table says "No related records". I've searched the forums and google and haven't seen this as a problem with anyone else. Is there something simple I'm missing?
RobertScheitlin__GISP
Eddie,
   I assume you have the showrelatedrecords tag set to true in the AttribruteTableWidget.xml
Docs: http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Attribute_Table_widget_tags/01m...
EddieArnold
Eddie,
Yes, that is correct. Which is why this is confusing. The attached attributes show up fine. But no related records. They do however show up in the popups and search quite nicely.
Eddie,
   Is the related table secured?
EddieArnold
Eddie,
One is and one isn't. They are not in the same viewer though. One is secured for editing. The other strictly for viewing.
Eddie,
  It sound like it could be related to this bug:
http://forums.arcgis.com/threads/86603-Token-does-not-work-on-my-related-table-in-my-dynamic-service...
I would give tech support a call on this issue though.
EddieArnold
Eddie,
Thanks! I'll give them a call.
