Query Widget - Results sorted Alphabetically or Numerically
4547
19
10-07-2010 11:57 AM
BrianKratcha
Is there an easy way to have my Query Widget return results sorted alphabetically or numerically?  Right now the results come back sorted randomly.
Brian
JonBeets1
If someone already has this done can you please send me the compiled widget?...
It's also interesting that a sorting feature wasn't built into the widget originally. No one wants to scroll through a 100 result query that's not sorted... 😉
Jon Beets
Jon.Beets@us.af.mil
BrianKratcha
Is anyone else having problems getting the above to work in 3.0?
MelissaPrindiville
I am having a problem with the code in version 3.  Any ideas on how to fix it?  No errors just doesn't sort.  I had it working in previous versions.
MarkHuffman
I tried this code for the first time in a version 3 viewer. I updated it to match changes between 2 and 3. I confirm that, although no errors are thrown, no sorting is done either. Can whoever has adapted the code successfully please post? Thanks.
Mark
daveespinosa-aguilar
also having same issues with 3... no errors, still queries, doesn't sort. looking into it further...
SerenaO_Connor
Just wondering has this been sorted for 3.0
I have a list of buildings which I need to show alphabetically and just wondering what code I should add.
<?xml version="1.0" ?>
<configuration>
    <layer>http://localhost:6080/arcgis/rest/services/UCC/Buildings/MapServer/0</layer>
    <query/>
    <titlefield>Name</titlefield>
    <linkfield>Name2</linkfield>
    <refreshrate>3</refreshrate>
    <zoomscale>15000</zoomscale>
    <fields all="false">
        <field name="Name" alias="Name"/>
    </fields>
</configuration>
Any help would be much appreciated.
S
BrianKratcha
So has anyone had any luck?
MarcWeinshenker1
For anyone following this thread, I found the same problem when converting to Flex Viewer 3.0 and I  have filed a support incident to see if this can be addressed.
[edit -- solution posted here http://forums.arcgis.com/threads/67832-Query-Widget-3.0-sort-results?p=236775&posted=1#post236775 ]
Marc
JohnGregorovic
Worked great for me, thank you for you help.
HeatherGonzago
