Query Widget - Results sorted Alphabetically or Numerically
6601
19
10-07-2010 11:57 AM
BrianKratcha
Is there an easy way to have my Query Widget return results sorted alphabetically or numerically?  Right now the results come back sorted randomly.
Brian
MarcWeinshenker1
Here's a solution I picked up off the forums a while back.  You'll need to edit QueryWidget.mxml and recompile.  In the function onResult, add the middle line as shown in the first code snippet to call a sorting function for the query results.
                            queryResultAC = createQueryResults(featureSet);
       queryResultAC = SortDataGridData("title",queryResultAC);
                            addSharedData(widgetTitle, queryResultAC);
Then put this sorting function somewhere in the module.
private function SortDataGridData(strFieldNameToSort:String,recACToSort:ArrayCollection):ArrayCollection{
    try{
     // CC -Orginal code by BJ and found at forum post http://forums.esri.com/Thread.asp?c=158&f=2421&t=285419&mc=6#msgid886159
     var dataSortField:SortField = new SortField();
     dataSortField.name=strFieldNameToSort;
     var alphabetDataSort:Sort = new Sort();
     alphabetDataSort.fields=[dataSortField];
     recACToSort.sort=alphabetDataSort;
     recACToSort.refresh();
    catch(error:Error){
    return recACToSort;
BrianKratcha
    try{
    catch(error:Error){
    return recACToSort;
Thanks for the reply RockvilleGIS,
One thing I had to add was this code below into the QueryWidget.mxml code to keep from getting an error.
                                      import mx.collections.SortField;
   import mx.collections.Sort;
   import mx.collections.ArrayCollection;
Thanks again,
Brian
R__CraigHolmes
NICE!
Thanks Gents.
I wasn't putting in the   import mx.collections.Sort;    along with the  import mx.collections.SortField;
She's sortin' now though!
TorstenSchramm
great work
thanks,
Torsten
JuneAcosta
I just added the above code to the query widget for Flex Viewer 2.2, but my data is still not sorting. I changed the "title" to the field name of my layer that I want to sort-- I get no errors, but still no sorting. Did anyone else run into this issue? Did you resolve it?
-June
KeithBornhorst
June,
Change the sort field back to "title" and the Query widget will sort your results based upon the <titlefield> specified in your widget config file. The embedded code only allows sorting on QueryResult fields (title, content, link, etc.). Additional, more complex code would be needed to support sorting on
alternative fields.
DerekTokarz1
I keep getting an error in Flex builder that says
"1013: The private attribute may only be used on class property definitions."
The error refers to the Array Collection field or line shown in the code below.
// for Alpha
      try{
      catch(error:Error){
      return recACToSort;
Any ideas as to what can be causing this. I am a beginner in flex so please bare with me.
Derek
JuneAcosta
Keith,
Thanks for the help- I would have never figured it out.
-june
SarahSchrader
Thank you!  This worked perfectly!!  The fact that our query list was not alphabetical was one of the first things my supervisor noticed and asked to have changed.  I'm glad that you already put this code together and shared it so I didn't have to figure out how to create this from scratch.
