Query Widget - Problem with SQL String
1565
04-04-2014 05:10 AM
RichardLittlefield
I'm using the query widget to perform a query. However I can't seem to get my query string to do what I want. I want it to say "[field name] IS NOT NULL", how do I say that in ArcGIS Viewer for Flex?
Also the wild card character in ArcGIS Viewer for Flex is the %, correct?
Thank you.
GeorgeHaskett
Are the values in your attribute table <NULL> or are they simply blank, there is a difference.
I just tested an example in one of my maps and this is how I wrote the query, with CLOSEDATE as the [FIELDNAME].
NOT CLOSEDATE is NULL
This worked for me.  Let me know if this format works for you.
Haskett
GeorgeHaskett
Haskett
GeorgeHaskett
Also, as for the wildcard question, here is a query I just tested and it works for my setup.
ADDRESSLINE1 LIKE '503%'
Haskett
RichardLittlefield
Haskett
Thank you very much! It works for me.
