Query Widget Polygon Color
2446
12-07-2010 07:02 AM
PaulSpahr
Hello,
Newbie to flex and html.  I've modified the QueryWidget_Louisville_PoliceStations to display a polygon map service.  The widget is functional, however, when using the widget the polygons appear as a transparent red fill with a red outline.  Is there a way to change this to display another color?
Paul
RobertScheitlin__GISP
Paul,
   Sure just add this to the SearchWidget.xml
<symbols>
     <simplefillsymbol color="0x00ff00" alpha="0.8">
      <outline color="0x00ff00" alpha="1" width="2"/>
     </simplefillsymbol>
    </symbols>
somewhere inside the configuration element (i.e. like at the very bottom before the </configuration>).
PaulSpahr
Awesome!  I used this site to pick out some new colors: http://www.colorpicker.com/
Thanks!
MaciejSarnowski
Anybody knows, why despite the fact that I put this line of code in my xml file, there are no changes?
Maciej Sarnowski,
   Sure... Based on your other thread you are missing an s at the end of symbol.
<symbols>
    <simplefillsymbol color="#000000" alpha="1">
                <outline color="#000000" alpha="1" width="2"/>
            </simplefillsymbol>
    </symbols>
MaciejSarnowski
Yeaaah!
Thank you very much Robert!
