Query Widget Memory Leak Problem
733
09-19-2011 06:13 AM
MattSheehan
I am loading a Query Widget in the Flex Viewer. Flash Builder gives the following warning on load:
warning: The class widgets.Query.QueryResult has been used in a call to net.registerClassAlias() in _QueryWidget_FlexInit. This will cause widgets.Query:QueryWidget to be leaked. To resolve the leak, define widgets.Query.QueryResult in the top-level application.
It relates to the following line in QueryResult.as:
[Bindable][RemoteClass (alias="widgets.Query.QueryResult")]
Wondered if anybody had a fix?
Thanks
--Rory
DelinWei
Under SDK 4.5.1, for Flexviewer 2.5, in your index.mxml, you can add these:
<s:Application
creationComplete="init()">
<fx:Script>
<![CDATA[
                        import flash.net.registerClassAlias;
                        import widgets.Query.*;
                        import widgets.Query.QueryResult;
                        private function init():void
       registerClassAlias("widgets.Query.QueryResult", QueryResult);
</fx:Script>
You can do the same for Bookmark, or IdentifyResult or similar issuses.
HAPPY FLEX!
Thanks
--Rory
