Query widget doesn't do anything
3869
10
03-11-2013 12:44 PM
HarryBoswell
I am trying to use the Query widget in the Viewer.  It seems to work - when I start the viewer, the query runs and displays a set of records.  But when I click on a row, nothing happens.  Help?
AnthonyGiles
Honored Contributor
HarryBoswell
Harry,
What did you set your zoom scale to?
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Query_widget/01m30000003m000000...
Regards
Anthony
I've tried the default;  I've tried 10,000; I've tried 2000.  It just sits there and stares back at me.
Harry
AnthonyGiles
Honored Contributor
Are you using a tiled base map and have you tried using one of the scales that the basemap has been cached to.
Do you also have the same problem when you deploy the app not just looking at it n the application builder?
Regards
Anthony
HarryBoswell
Regards
Anthony
Same thing happens on the deployed map.  It's like I haven't told it to do anything.  I feel like there's something basic about the Query widget I'm not getting.
Harry
AnthonyGiles
Honored Contributor
Harry,
Does the .xml file that the application builder creates for the widget contain a zoomscale tag?
Regards
Anthony
HarryBoswell
Harry,
Regards
Anthony
Yes... here's the file:
<configuration>
    <layer>http://bsegrest-edn/ednarcgis/rest/services/CTS/CTS/MapServer/1</layer>
    <query>STATUS_DESC = 'New'</query>
    <titlefield>CTS.COMPLAINT_LOCATION_Features.COMPLAINT_ID</titlefield>
    <linkfield/>
    <refreshrate/>
    <zoomscale>20000</zoomscale>
    <shareresults>false</shareresults>
    <orderbyfields>CTS.COMPLAINT_LOCATION_Features.COMPLAINT_ID</orderbyfields>
    <fields all="false">
        <field name="CTS.COMPLAINT_LOCATION_Features.COMPLAINT_ID" alias="COMPLAINT_ID"/>
        <field name="CTS.COMPLAINT_LOCATION_Features.LATITUDE_DECIMAL" alias="LATITUDE"/>
        <field name="CTS.COMPLAINT_LOCATION_Features.LONGITUDE_DECIMAL" alias="LONGITUDE"/>
    </fields>
</configuration>
AnthonyGiles
Honored Contributor
I'm sorry I don't know what else to suggest
Anthony
HarryBoswell
This morning I tried using the Search widget, and the same thing happens - I can get results in the popup, but nothing happens when I click on a row.  There's something I'm missing here.
Harry
HarryBoswell
Ahhh..... found the problem.  I hadn't made the Shape field available to the Flex viewer.  It's all good now.
Harry
