Problem with Query Expression in Enhanced Search Widget
1629
09-11-2012 08:15 AM
MichaelVolz
Esteemed Contributor
In the Enhanced Search Widget, I have the following configuration where I am trying to query against a numeric field if the value is less than the user input value.
<value prompt="Example: Lower Range Assessed Value (AV) AV < 100000 - Just enter value" isvaluerequired="false">(PROP_ASSESS) < ([value])</value>
This is the error message I receive:
A problem occurred while parsing the configuration file widgets/eSearch/eSearchWidget_1.xml
Error #1095
If I have the following config value:
<value prompt="Example: Lower Range Assessed Value (AV) AV > 100000 - Just enter value" isvaluerequired="false">(PROP_ASSESS) > ([value])</value>
everything works fine.
Any idea what the problem could be?
RobertScheitlin__GISP
Michael,
   Try this:
<value prompt="Example: Lower Range Assessed Value (AV) AV &lt; 100000 - Just enter value" isvaluerequired="false">PROP_ASSESS &lt; [value]</value>
The reason is the xml parser is thinking that that is the beginning of a new element
Michael,
   Here is what you need:
<value prompt="Example: Lower Range Assessed Value (AV) AV < 100000 - Just enter value" isvaluerequired="false">PROP_ASSESS &lt; [value]</value>
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow the steps as shown in the below graphic:
MichaelVolz
Robert:
I am still getting the same error message.
Also, why does the > sign work but not the < sign?
Michael,
   Try this:
MichaelVolz
Robert:
Wouldn't the > sign also cause an error as it would make the xml parser think that that is the end of an element and the next element would not have the correct syntax?
Michael,
   For some reason it handles that one correctly.
