Problem for widget open on eDraw and close Identify
800
10-15-2013 06:13 AM
MayJeff
When eDraw widget is opened, I added this line to close identify widget AppEvent.dispatch(AppEvent.WIDGET_CLOSE, ViewerContainer.getInstance().widgetManager.getWidgetId("Identify"))  inside these function - basewidget_widgetConfigLoaded(),  activateDrawTool(), and wTemplate_openHandler().   But Identify tool icon and hover tooltip on identify widget will still show up on the application.  See the attachment.
Does anyone has this minor problem?
Thank you.
RobertScheitlin__GISP
May Jeff,
   This is how you need to close a widget:
                var wId:Number = ViewerContainer.getInstance().widgetManager.getWidgetId("Identify");         var data:Object = {             id: wId,             state: WidgetStates.WIDGET_CLOSED          }         AppEvent.dispatch(AppEvent.WIDGET_STATE_CHANGED, data);
May Jeff,
MayJeff
Robert,
I added the code you provided but Identify widget won't close when eDraw is opened. Can you tell what is the different to use AppEvent.dispatch(AppEvent.WIDGET_CLOSE, ViewerContainer.getInstance().widgetManager.getWidgetId("Identify")) & the code you provided?
If I change the code to this then Identify widget will close.
___________________________________________________________
for each (var widgetId:Number in ViewerContainer.getInstance().widgetManager.getAllLoadedWidgetIds()) {
    if(widgetId == 3) {
    var data:Object = {
    AppEvent.dispatch(AppEvent.WIDGET_CHANGE_STATE, data);
____________________________________________________________
Thank you very much.
