Print with Feature Attributes
2666
9
03-25-2011 05:28 AM
MelissaJohnson
I am looking for a way to print a map from the Flex Viewer with the search attributes.  I do not want them to print on the map, but maybe on the side of the print page.  Ideally I would like to give the user a choice between printing map and search results info, or just the map (maybe through the use of checkboxes or radio buttons).
For example, the user searches for a parcel number and when the parcel is selected and they zoom in, they can click Print and the Alive PDF prints out a map with the parcel map on the left and the fields that are specified in the SearchWidget xml file on the right in a table.  Does anyone have any ideas on how this could be accomplished?
See attachment from our current IMS site.  This is what I am shooting for but it doens't have to be exactly the same.
Melissa
MelissaJohnson
I am looking at the Attribute Inspector, and I wonder if there would be a way to do something similar to the "Attribute Inspector outside of Map sample", except within the pdf mxml.  Sorry I am learning Flex and trying to work it all out how things are connected.
Thanks in advance!
Melissa
MGSethe
Melissa
I am spending sleepless nights trying to implement exactly what you want, Did you find a solution for this, Please share with me the could you have to get me going.
Golden
MelissaJohnson
Robert Scheitlin had posted some code of what he does on his website, but I haven't had time to do anything with it and I can't find the post here on the forum.  It will take me a while to get it to work.
We will be using a Silverlight product that has already been built as our main mapping site instead of Flex (that print sheet with options for attributes is already part of the package).  I still plan on using Flex for other small projects as I have time. Good luck!  If you find something please post!
Melissa
LonSharp
Does anyone know how to accomplish this?   I need to have parcel attributes print below the map, rather than on it.   The default obscures map detail.
Thanks.
BillLotz
Thanks.
Add me to the list!
AdamMcArthur1
I too am currently working on this issue, but have yet to find a solution.
If anyone knows how to implement this in Flex Viewer 3.0, it would be much appreciated.
DerekHunter1
I too am working on pulling in a datagrid for selected graphics into the Print Widget.  If anyone can comment on accomplishing this (for a novice programmer), that would be awesome.
LonSharp
Still looking for a solution for this.   I'm currently migrating to 3.1
OlegLukyanov
Does anyone use a geoprocessing service for this task? I look for any samples.
I'm interesting how I can insert picture from attachments for such report with map and feature attributes also.
Thanks
Oleg.
