parsing error in config.xml (need 2nd set of eyes, please)
2362
06-20-2014 10:53 AM
TimHayes
I cannot figure out why I keep getting a parsing error #1085 when I try and open my flex viewer 3.6 (I am using the compiled version). I have stared at this too long, can I have a second set of eyes take a look. thanks.
Here the code from my config.xml file:
<?xml version="1.0" ?>
// Read more about ArcGIS Viewer for Flex - http://links.esri.com/flexviewer
<configuration>
    <title>Map Viewer</title>
    <subtitle>Facility</subtitle>
    <logo>assets/images/RWFLogo1.png</logo>
    <style>
        <colors>0xFFFFFF,0x333333,0x101010,0x000000,0xFFD700</colors>
        <alpha>0.8</alpha>
    </style>
    <!-- replace the following url with your own geometryservice -->
    <geometryservice url="http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer" />
    <!-- UI elements -->
    <widget left="10"  top="50"    config="widgets/Navigation/NavigationWidget.xml" url="widgets/Navigation/NavigationWidget.swf"/>
    <widget right="0" bottom="0"   config="widgets/OverviewMap/OverviewMapWidget.xml" url="widgets/OverviewMap/OverviewMapWidget.swf"/>
    <widget right="20" top="55"    config="widgets/MapSwitcher/MapSwitcherWidget.xml" url="widgets/MapSwitcher/MapSwitcherWidget.swf"/>
    <widget left="0"   top="0"     config="widgets/HeaderController/HeaderControllerWidget.xml" url="widgets/HeaderController/HeaderControllerWidget.swf"/>
    <map wraparound180="true" initialextent="-14083000 3139000 -10879000 5458000" fullextent="-20000000 -20000000 20000000 20000000" top="40" addarcgisbasemaps="true">
         <basemaps>
              <layer type="tiled" label="Streets" icon="https://www.arcgis.com/sharing/rest/content/items/d8855ee4d3d74413babfb0f41203b168/info/thumbnail/te..." url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer" visible="true"/>
              <layer type="tiled" label="Imagery" icon="https://www.arcgis.com/sharing/rest/content/items/86de95d4e0244cba80f0fa2c9403a7b2/info/thumbnail/te..." url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer" visible="false"/>
         </basemaps>
         <operationallayers>
              <layer type="dynamic" label="Air Systems" url="http://mygisserver:0000/arcgis/rest/services/rAirProcessStreams/MapServer" visible="false">
         </operationallayers>
    </map>
    <!-- widgets organized into widget containers that manage close/open etc -->
    <!-- supported layout property options: horizontal(default)|float|vertical|fix-->
    <widgetcontainer layout="float">
        <widget label="Print" left="390" top="400"
                icon="assets/images/i_print.png"
                config="widgets/Print/PrintWidget.xml"
                url="widgets/Print/PrintWidget.swf"/>
        <widget label="My first widget"
                icon="assets/images/i_widget.png"
                config="widgets/Samples/HelloWorld/HelloWorldWidget.xml"
                url="widgets/Samples/HelloWorld/HelloWorldWidget.swf"/>
    </widgetcontainer>
</configuration>
MichaelMiller2
<configuration>
<style>
<alpha>0.8</alpha>
</style>
<basemaps>
<layer type="tiled" label="Streets" icon="https://www.arcgis.com/sharing/rest/content/items/d8855ee4d3d74413babfb0f41203b168/info/thumbnail/tempstreets.jpg" url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer" visible="true"/>
<layer type="tiled" label="Imagery" icon="https://www.arcgis.com/sharing/rest/content/items/86de95d4e0244cba80f0fa2c9403a7b2/info/thumbnail/tempimagery.jpg" url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer" visible="false"/>
</basemaps>
<operationallayers>
</map>
</widgetcontainer>
</configuration>
Looks like you are missing a "/" to close your layer.
<operationallayers> <layer type="dynamic" label="Air Systems" url="http://mygisserver:0000/arcgis/rest/services/rAirProcessStreams/MapServer" visible="false"/> </operationallayers>
MichaelMiller2
<configuration>
<style>
<alpha>0.8</alpha>
</style>
<basemaps>
</basemaps>
<operationallayers>
</map>
</widgetcontainer>
</configuration>
TimHayes
Thanks. I closed my layer, but I still keep getting the parsing error.
TimHayes
Stupid me! I also forgot to add the close for </basemaps>
It works now. Thanks.
