Pan Speed | panEasingFactor
3145
11-18-2010 08:41 AM
ThomasFair
I know the panEasingFactor is set by default to .2. I want to change it to 1 or turn it off, but I can't find where this is set or how to change this. Please help.
BjornSvensson
Esri Alum
Setting the "panEasingFactor" is not an option that is available thru default configuration xml files, though this widget might help:
http://www.arcgis.com/home/item.html?id=4837907e122246a893c9746a018fcd38
If you are working with API, it's a property on Map.
http://help.arcgis.com/en/webapi/flex/apiref/com/esri/ags/Map.html#panEasingFactor
If you are working with the Flex Viewer 2.1 source code, you could probably change it in FlexViewer\src\com\esri\viewer\skins\MapManagerSkin.mxml where the Map is defined.
