Operational Layers shifting When Zoom in and Zoom Out
748
04-26-2011 10:36 PM
Arusham
I had downloaded the new Arcgis flex viewer 2.3 and i had changed the base map and operational layers in config.xml when i run the application operational layer gets shifted when zoom in and zoom out and even the spatial refrence is same, please suggest me a solution. U can click on this link to see the issue
http://maps.ijanaagraha.org/Viewer/bin-debug/index.html
Regards
Arun Mohan
DasaPaddock
There is a bug in the API that's causing this issue when the layers are cached at the same scales and spatial reference, but have different DPI and resolutions.
Can you rebuild one of the layers so that it has the same DPI and resolutions as the other one?
