minimize widget after getting results
2002
10
01-10-2012 08:32 AM
PeterHoffman
I am looking for a way to automatically minimize a widget after clicking
on a button in a custom locate widget.
The user wants to locate an item and then automatically minimize the widget.
I have searched but not found any code that would do this.
RobertScheitlin__GISP
Peter,
   Glad you got it working. Don't forget to click the top arrow (promote) and to click the Mark as answer check as shown below:
Peter,
   Sure just dispatch the right AppEvent:
This code goes in the LocateWidget.mxml
Add this Import:
import com.esri.viewer.AppEvent;
            private function showLocation(data:Object):void
                hideInfoWindow();
                graphicsLayer.clear();
                var ptGraphic:Graphic = new Graphic();
                ptGraphic.geometry = data.point;
                graphicsLayer.add(ptGraphic);
                var popUpInfo:PopUpInfo = new PopUpInfo();
                popUpInfo.title = data.title;
                popUpInfo.description = data.content;
                var infoWindowRenderer:ClassFactory = new ClassFactory(PopUpRenderer);
                infoWindowRenderer.properties = { popUpInfo: popUpInfo };
                graphicsLayer.infoWindowRenderer = infoWindowRenderer;
                popUpRenderer.popUpInfo = popUpInfo;
                popUpRenderer.graphic = ptGraphic;
                if (map.scale > zoomScale)
                    map.scale = zoomScale;
                map.centerAt(data.point);
                infoWindowShow();
//Added Code
                var data:Object = {
                    state: "minimized"
                AppEvent.dispatch(AppEvent.WIDGET_CHANGE_STATE, data);
//End Added Code
PeterHoffman
Robert,
The code I have has been highly modified by a consultant and this is the closest I could find to the showLocation function I have,
it is passing in a data of type array and not object.
Website:  http://gis.co.suffolk.ny.us/shelters4/index.html and widget is the "Find Closest Shelter".
function locateResult(data:Array, token:Object = null):void
     if (data.length > 0)
      var addrCandidate:AddressCandidate = data[0];
      locPoint = addrCandidate.location;
      locationGraphicsLayer.add(new Graphic(locPoint, pmsLocation));
      map.centerAt(locPoint);
      while(map.scale > 50000)
       map.zoomIn();
      gButtons.visible = true;
      gFacilities.visible = true;
      qryStormSurge.geometry = locPoint as Geometry;
      qryStormSurge.spatialRelationship = Query.SPATIAL_REL_INTERSECTS;
      qtStormSurgeTask.execute(qryStormSurge, new AsyncResponder(queryStormSurgeResult, genericError));
     else
      showMessage("Could not locate an address using on the Street, City, and Zip values.", false);
Peter,
   OK, So you just need to put the comment code I provided in the last function that gets called. Maybe queryStormSurgeResult (not sure without seeing the whole code).
PeterHoffman
Robert,
Thnaks for the quick replys.
Now I get this error message:
Multiple markers at this line:
-1061: Call to a possibly undefined method dispatch through a reference with static type Class.
Line of code:
AppEvent.dispatch(AppEvent.WIDGET_CHANGE_STATE, data2);
Peter,
   Yep that code is for Flex Viewer 2.5 not 2.2. Try this line instead
ViewerContainer.dispatchEvent(new AppEvent(AppEvent.WIDGET_CHANGE_STATE, data2));
PeterHoffman
Now I get:
1120: Access of undefined property ViewerContainer. FindClosestWidget.mxml /SuffolkSheltersEric/src/widgets/Locate line 598 Flex Problem
Peter,
   I keep forgetting your not a developer:
Add this import at the top with the others
import com.esri.viewer.ViewerContainer;
PeterHoffman
No, I am not a developer, I am not supposed to be even doing any programming according to my job title but I do anyhow to get the job done.
I did try typing in the import com.esri.viewer. and did not get the intellisense to show me ViewContainer as an option.
The minimize feature works great!
Thanks for your help again.
Peter,
