Migrating from Flex Viewer to API for Flex
1060
12-29-2010 06:41 AM
by Anonymous User
Not applicable
I am currently using the free viewer provided by ESRI, I am thinking of downloading API for Flex application.  I know there is more options available using the API, but I'm not a programmer so I don't know if its worth the hassle to change to the API for Flex.
Is it difficult to migrate/convert to the API for Flex?  Any good suggestions on how to migrate/convert from the free viewer to API for Flex?
Thanks in advance for the suggestions/comments!
Todd
RobertScheitlin__GISP
Todd,
   The Flex API is the base that the free FlexViewer is built upon. The API allows you to build Flex GIS apps from scratch. The Viewer uses widgets and a kind of MVC design pattern. If you want to start building apps from scratch then I would suggest starting with the samples that esri have provided.
http://help.arcgis.com/en/webapi/flex/samples/index.html
by Anonymous User
Not applicable
I would assume that you would recommend downloading/installing the Flex API Library?
by Anonymous User
Not applicable
thanks for the help!!
