LayerList widget - description button
3105
07-30-2013 03:51 AM
PEREZvincent
is it possible to configure the description button of the LayerListWidget?
I want, for all my layers, to make links toward HTML pages that describe the layers.
I don't wanted to be redirected on the REST services directory.
(my config : AGS 10.1 - flex 3.0)
thank you,
Vincent
RobertScheitlin__GISP
Vincent,
   That is not a currently supported configurable option. It is easy to change in the code (not xml) if you have access to the source code and a Flex IDE like Flash Builder.
You would make your changes in the:
The function descriptionOrDownloadLabel_clickHandler is what gets called when you click the description button:
src/com/esri/viewer/components/toc/tocClasses/TocLayerMenu.mxml
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow these steps as shown in the below graphic:
Vincent,
PEREZvincent
ok thank you Robert.
I don't have Flash builder and I don't speak flex...
I'll see if I can learn it!
regards,
Vincent
PEREZvincent
First, as said Robert, I solved my problem by modifying the contents of the descriptionOrDownloadLabel function by :
var request:URLRequest = new URLRequest("http://xxx");
navigateToURL(request, "_blank");
It work fine. But users are redirect toward the same html page
But now I would like to redirect the users towards differents metadatas (1 layer => 1 html page).
Is it possible to include a new XML tag in the main config file (for each operationallayers) and call this XML tag in the descriptionOrDownloadLabel function of the tocLayermenu.mxml ?
Vincent,
   It might be possible but as the layers in the main config.xml can be individual layer (feature type) or mapservices (dynamic type) which would contain many layers, this would not work well. It would also involve changing/adding code to many file in the viewer and is to in depth for me to help with.
You do have access to the layer from the descriptionOrDownloadLabel function and could use the copyright property to hold the url you want to use.
