Expand and collapse layers in map service
1129
09-25-2013 07:25 AM
RebeccaWatson
Am I imagining that when I used to publish map services, they were published so they appeared in my flex application with the exact same collapsed and expanded layers as show in the mxd used to publish it?
Now, when I publish a map service all the layers are collapsed. You can't pick and choose expanded and contracted layers in flex app builder, only ALL layers are expanded (too much) or ALL layers are collapsed (too little) which is causing a bit of problem.
Am I missing something that I used to do?
erkansahin
mr. did you find resolve?
RebeccaWatson
No, I never did solve this issue. I have started looking into whether I can have a save layer preferences prompt come up when the user shuts down the viewer so that their layers are saved for them as I think that this will be more useful because I have a wide range of users and they all have slightly different requirements.
