Identify tool and Links
903
06-02-2011 10:33 PM
VladislavMasatin
I have a small problem with identify tool. There is part of configuration file:
<layer>
<name>Chamber</name>
<fields>MARK,Z</fields>
<linkfield>MARK</linkfield>
<linkprefix>files/chamber/</linkprefix>
<linksuffix>.pdf</linksuffix>
<iconfield></iconfield>
<iconprefix></iconprefix>
<iconsuffix></iconsuffix>
<zoomscale>500</zoomscale>
<forcescale>true</forcescale>
</layer>
So when I click on object I see working link, and the Z field value, but It would be great if I also see the MARK field value in identify window.
RobertScheitlin__GISP
Vladislav,
   The identify tool is developed like all the other esri widgets and a field can either be displayed in the results like other fields or it can be used as a link, that's just the way it works.
JhonDilinger
Sorry, but how works identify tool, how it gets object info from SDE data base
or where I can read this, need some manual-book (.net (c#/asp) / javascript / js api ) ..or else
I would like programming my own same "tool" for ArcGis Application
