private function widgetClosedHandler(event:Event):void
clear();
setMapAction(null, null, null, null);
graphicsLayer.visible = false;
hideInfoWindow();
setMapNavigation(null, null);
if (selectedDrawingIcon)
selectedDrawingIcon = null;
} private function widgetOpenedHandler(event:Event):void
if(graphicsLayer)
graphicsLayer.visible = true;
if (autoActivatedTool != "" )
activateIdentifyTool(null, autoActivatedTool);
Eric,
Clearing the results on widget close would be as simple as adding the clear(); function to the widgetClosedHandler...private function widgetClosedHandler(event:Event):void { clear(); setMapAction(null, null, null, null); graphicsLayer.visible = false; hideInfoWindow(); setMapNavigation(null, null); if (selectedDrawingIcon) selectedDrawingIcon = null; }
Your second request just as simple 2 lines this time:private function widgetOpenedHandler(event:Event):void { if(graphicsLayer) graphicsLayer.visible = true; if (autoActivatedTool != "" ) activateIdentifyTool(null, autoActivatedTool); }
private function activateIdentifyTool(event:MouseEvent, lTool:String = ""):void
addSharedData("Deactivate_DrawTool", null); // to be able to deactivate drawTool on other widgets
// apply glow
if(event){
selectedDrawingIcon = Image(event.currentTarget);
}else{
switch(lTool){
case DrawTool.EXTENT :
selectedDrawingIcon = iDrawExt;
break;
case DrawTool.POLYGON :
selectedDrawingIcon = iDrawPoly;
break;
case DrawTool.MAPPOINT :
selectedDrawingIcon = iDrawPnt;
break;
case DrawTool.POLYLINE :
selectedDrawingIcon = iDrawLine;
break;
default:
clearSelectionFilter();
selectedDrawingIcon.filters = [ glowFilter ];
var status:String;
var value:String = selectedDrawingIcon.name;
lastTool = selectedDrawingIcon.name;
setMapNavigation("none", "");
switch (value)
case DrawTool.MAPPOINT:
status = pointLabel;
setMapAction(DrawTool.MAPPOINT, status, identMarkerSymbol, drawEnd, false);
break;
case DrawTool.POLYLINE:
status = lineLabel;
setMapAction(DrawTool.POLYLINE, status, identLineSymbol, drawEnd, false);
break;
case DrawTool.EXTENT:
status = rectLabel;
setMapAction(DrawTool.EXTENT, status, identFillSymbol, drawEnd, false);
break;
case DrawTool.POLYGON:
status = polyLabel;
setMapAction(DrawTool.POLYGON, status, identFillSymbol, drawEnd, false);
break;
