Hi
I have 32 layers in my flex application.Is there any way to make groups of these layers like ArcGIS Desktop?
I can not do this in ARCGIS DESKTOP, because some layers are cashed and some layers are dynamic.
Regards
Yes, the config that is supplied with the widget works with the default config file when you download the viewer using the fires and demographic layers
Anjelina,
Many have requested this but it is not an option in Flex Viewer. There was a widget back several versions ago that sort of did this but it is not compatible with the current versions.
What is the name of that widget?
If it is not compatible with flex 3.6, is there other solution?
the the source code for the widget can be found here:
WestonSF/ArcGISFlexViewerTOCGroupWidget · GitHub
but it will require you to have the ability to compile source code
Something like the group toc but no there is no solution for 3.6
Do you can help me more, or write a widget?
Angelina,
Nope this one is way to complicated and involved.
I,m looking for a expert flex developer. my email is:
anjelinaponkerat@gmail.com
Signed in members can post, follow updates, and more. New here? Register a free account.
