How we can make a group of layers?
6291
25
07-28-2014 11:08 AM
anjelinaponkerat
Hi
I have 32 layers in my flex application.Is there any way to make groups of these layers like ArcGIS Desktop?
I can not do this in ARCGIS DESKTOP, because some layers are cashed and some layers are dynamic.
Regards
anjelinaponkerat
Hi
Many thanks. Is it possible send me source code of this widget to develope by flash builder?
AnthonyGiles
Honored Contributor
Its the code in the link to the github page in my post above.
anjelinaponkerat
Hi
I have problem with TOCGroup.xml configuration. What is "Theme" and "mapservice" configuration?
AnthonyGiles
Honored Contributor
Themes are the groups you want to make, then you have to specify which map services you want in each theme using the layer name
anjelinaponkerat
Hi
map service is equal of Layer label in config.xml or ...?
please help...
AnthonyGiles
Honored Contributor
Yes, the config that is supplied with the widget works with the default config file when you download the viewer using the fires and demographic layers
haThach
I download the source code and add it to my flex project but got this error. What does it mean?
1119: Access of possibly undefined property SUSPEND_TOC_HIDE_TIMER through a reference with static type class.
Regards,
Ha Thach
RobertScheitlin__GISP
Ha Thach,
    You get that error because the widget is not updated for ArcGIS Viewer for Flex 3.6
haThach
Thanks Robert. Yes, I'm using ArcGIS Viewer for Flex 3.6. When I comment out error message in TransparencyMenuItem.mxml and TocLayerMenu.mxml
where
//AppEvent.dispatch(AppEvent.SUSPEND_TOC_HIDE_TIMER, "true");
//AppEvent.dispatch(AppEvent.SUSPEND_TOC_HIDE_TIMER, null);
Now, the error message go away. This seem to solve the problem temporarily. Are you or the person who wrote this source code have any plan on update this TOCGroup widget?
Ha Thach,
  I don't think the original developer is maintaining this widget any more but if you really want this widget updated then these are the changes to make.
TocLayerMenu.mxml
            private function bordercontainer1_rollOverHandler(event:MouseEvent):void
                AppEvent.dispatch(AppEvent.RESET_TOC_HIDE_TIMER, "true");
            private function bordercontainer1_rollOutHandler(event:MouseEvent):void
                AppEvent.dispatch(AppEvent.START_TOC_HIDE_TIMER, null);
            protected function transparencyBorderContainer_rollOverHandler(event:MouseEvent):void
            protected function transparencyBorderContainer_rollOutHandler(event:MouseEvent):void
