How to run specific application configuration in Flash Builder?
928
07-01-2011 12:41 AM
KamilSvoboda
Is there any way, how to setup Flash Builder's "Run configuration", to run/debug specific ArcGIS Viewer for Flex application configuration?
In Run > Run Configurations can be set "Url or path to launch", where I can uncheck "Use Default" and I can set new path with configuration URL parameter - for example "C:\Users\user\Adobe Flash Builder\flex_viewer\bin-debug\index.html?config=config.xml". But debug results with Launch Error - File not found.
Is there any other way to run/debug specific application cofniguration in Flash Builder?
Thanks a lot!
Kamil
RobertScheitlin__GISP
Kamil,
   The easiest way is to open the ViewerContainer.mxml and set the line:
public static const DEFAULT_CONFIG_FILE:String = "config.xml";
But if you want to know how to fix the error you are getting you have to have the url set to a valid http url. It can not use the file system like C:\Users\user\Adobe Flash Builder\flex_viewer\bin-debug\index.html?config=config.xml. It would have to be http:\\localhost\Flexdev\index.html?config=config.xml
KamilSvoboda
Robert,
thank you for that advice! Using correct http URL is right way, because I need to prepare more "Run configurations" for different apps. Therefore change of DEFAULT_CONFIG_FILE isn't sufficient.
Thanks again!
Kamil
