How to create attribute inspectors inspectorFields with actionscript?
1435
02-07-2012 03:05 AM
MarttiKostia
Hello.
I need to create an attribute inspector window with actionscript, because the field inspectors need to be created dynamically.
In mxml, I can just go
  <esri:FieldInspector id="myFieldInspector" featureLayer="{myLayer}" fieldName="MYFIELD"  label="My Field">    <esri:renderer>     <fx:Component>      <esri:DropDownListField>       <esri:dataProvider>        <s:ArrayCollection>         <fx:Object label="Red" value="RED"/>         <fx:Object label="Green" value="GREEN"/>        </s:ArrayCollection>       </esri:dataProvider>      </esri:DropDownListField>     </fx:Component>    </esri:renderer>   </esri:FieldInspector>.
In actionscript, I can go:
myFieldInspector.renderer = myFieldInspectorRenderer, and then do the renderer in a separate mxml.
The fieldInspector should be a textInput or a textArea, and changes to those fields should go to the database.
What should the renderer contain for this? The fieldInspector has correct the featurelayer and the field name.
MarttiKostia
Thank you Robert,
I did look at that thread first, but I couldn't figure out from the answers how the data in the renderer's textInput gets stored into the db.
I figured it out though: the renderer can be a standard item renderer:
<?xml version="1.0" encoding="utf-8"?> <s:ItemRenderer xmlns:fx="http://ns.adobe.com/mxml/2009"      xmlns:s="library://ns.adobe.com/flex/spark"      xmlns:mx="library://ns.adobe.com/flex/mx"      xmlns:managers="com.esri.viewer.managers.*"     autoDrawBackground="true"      width="100%" xmlns:esri="http://www.esri.com/2008/ags"     >  <fx:Script>   <![CDATA[        override public function set data(value:Object):void {     if (value) input.text = String(value);    }      ]]>  </fx:Script>    <esri:StringField id="input" width="200" />     </s:ItemRenderer>
With the exception that I use <esri:StringField> instead of spark textinput.
Apparently the StringField manages to do the trigger the submitting to database automatically.
RobertScheitlin__GISP
Martti,
   See this thread for an example:
http://forums.arcgis.com/threads/19995-Easiest-way-to-customize-AttributeInspector-associated-with-a...
Don't forget to click the Mark as answer check and to click the top arrow (promote) as shown below:
MarttiKostia
Thank you Robert,
