How to control decimals in eSearch widget's datagrid?
2782
10
07-16-2014 09:35 AM
LeiZhou
I want to keep 2 decimals for a variable in eSearch widget.  Can I use numberformat to control decimals? The following code only keep integer.  Thanks!
<field name="minor" alias="Percent Minority" numberformat="0|,|." gridfield="true"/>
RobertScheitlin__GISP
Lei,
    That is because you have the number of decimals set to 0 change it to 2.
<field name="minor" alias="Percent Minority" numberformat="2|,|." gridfield="true"/>
Lei,
LeiZhou
I tried this, but it seems nothing changed. I also change it to 4|,|. or 100|,|.  Thanks!
Lei,
  What is the data type of the field? When I set the numberformat on any numeric field it works fine for me.
<field name="PPIN" gridfield="true" alias="Parcel Identifcation Number" numberformat="6|,|."/>
LeiZhou
It is esriFieldTypeDouble; if I remove numberformat, the data goes back to original .**** four decimals
Thanks!
Lei,
   Can you attach your whole eSearchWidget.xml for me to look at?
LeiZhou
<configuration>
      <layers>
            <layer>
                  <definitionexpression></definitionexpression>
                  <enableexport>false</enableexport>
                  <name>Health Indicators</name>
                  <url>I hide url since it is not public</url>
                  <expressions>
                        <expression alias="Census Tract" textsearchlabel="Search by Census Tract [Example: 48201532100]:"
                        >ct_arr.FIPS LIKE '%[value]%'</expression>
                  </expressions>
                  <graphicalsearchlabel>Use a tool to select one or more Census Tracts</graphicalsearchlabel>
                  <spatialsearchlayer>true</spatialsearchlayer>
                  <titlefield></titlefield>
                  <fields all="false">
                        <field name="ct_arr.FIPS" alias="Census Tract" gridfield="true"/>
                        <field name="all.pop_per_sq" alias="Population Density" numberformat="0|,|." gridfield="true"/>
                        <field name="all.pct_minor" alias="Percent Minority" numberformat="0|,|." gridfield="true"/>
                        <field name="all.pct_black" alias="Percent Black" numberformat="0|,|." gridfield="true"/>
                        <field name="all.pct_hispan" alias="Percent Hispanic" numberformat="0|,|." gridfield="true"/>
                        <field name="all.pct_asian" alias="Percent Asian" numberformat="0|,|." gridfield="true"/>
                        <field name="all.pct_povert" alias="Percent Below Poverty" numberformat="0|,|." gridfield="true"/>
                        <field name="all.MHI" alias="Median Household Income" numberformat="0|,|." gridfield="true"/>
                        <field name="all.pct_no_HS" alias="Percent Without High School Diploma" numberformat="0|,|." gridfield="true"/>
                        <field name="all.pct_hsh_fe" alias="Percent of Female Head of Households" numberformat="0|,|." gridfield="true"/>
                        <field name="all.avg_comm_t" alias="Average Travel Time to Work" numberformat="0|,|." gridfield="true"/>
                        <field name="all.pct_no_veh" alias="Percent Households without a Vehicle" numberformat="0|,|." gridfield="true"/>
                        <field name="all.bkw_ch" alias="Percent of Children Living within a 1/4 mile of a Bikeway" numberformat="0|,|." gridfield="true"/>
                        <field name="all.bus_w" alias="Percent of Adults Living within a 1/4 Mile of a Bus Stop" numberformat="0|,|." gridfield="true"/>
                        <field name="all.es_ch" alias="Percent of Children Living with a 1/4 mile of an Elementary School" numberformat="0|,|." gridfield="true"/>
                        <field name="all.prk_pop" alias="Percent of Resdients Living within a 1/4 Mile of a Park" numberformat="0|,|." gridfield="true"/>
                        <field name="all.int_sqm" alias="Intersection Density (street intersections per square mile)" numberformat="0|,|." gridfield="true"/>
                        <field name="all.parks_sqm" alias="Parks per Square Mile" numberformat="2|,|." gridfield="true"/>
                        <field name="all.grocery_sq" alias="Supermarkets per Square Mile" numberformat="2|,|." gridfield="true"/>
                        <field name="all.fastfood_s" alias="Fast Food Restaurants per Square Mile" numberformat="4|,|." gridfield="true"/>
                        <field name="all.supm_pop" alias="Supermarkets per 1,000 Residents" numberformat="0|,|." gridfield="true"/>
                        <field name="all.ff_pop" alias="Fast Food Restaurants per 1,000 Residents" numberformat="0|,|." gridfield="true"/>
                        <field name="all.PerObOvr" alias="Percent of Children Overweight" numberformat="0|,|." gridfield="true"/>
                  </fields>
                  <linkfield></linkfield>
                  <icon isfield="false">assets/images/i_target.png</icon>
                  <zoomscale>145000</zoomscale>
                  <autoopendatagrid>true</autoopendatagrid>
            </layer>
    </layers>
      <spatialrelationships>
            <spatialrelationship>
                  <name>esriSpatialRelContains</name>
                  <label>entirely contained in</label>
            </spatialrelationship>
                  <name>esriSpatialRelIntersects</name>
                  <label>interssected by</label>
                  <name>esriSpatialRelEnvelopeIntersects</name>
                  <label>intersected by envelop of</label>
      </spatialrelationships>
      <bufferunits>
            <bufferunit>
                  <name>UNIT_FOOT</name>
                  <label>Feet</label>
            </bufferunit>
            <bufferunit>
                  <name>UNIT_STATUTE_MILE</name>
                  <label>Miles</label>
            </bufferunit>
            <bufferunit>
                  <name>UNIT_METER</name>
                  <label>Meters</label>
            </bufferunit>
            <bufferunit>
                  <name>UNIT_KILOMETER</name>
                  <label>Kilometers</label>
            </bufferunit>
      </bufferunits>
      <tolerance>6</tolerance>
      <spatialReference>102003</spatialReference>
      <zoomscale>2400</zoomscale>
      <geometryservice>http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer</geometryservice>
      <csvSeparator>,</csvSeparator>
      <toleranceforpointgraphicalselection>3</toleranceforpointgraphicalselection><!-- value is in screen pixels -->
      <disablebuttons></disablebuttons><!--possible values one or more not all three search types comma sepearted text,graphic,spatial,grid -->
      <defaultselectionoption>graphicalInput</defaultselectionoption><!--possible values only one graphicalInput or textInput or spatialInput -->
      <enabledrawgraphicbutton>true</enabledrawgraphicbutton>
      <labels>
            <addtolerance>Add search tolerance to point selection</addtolerance>
            <existingdrawgraphicslabel>Use Existing Draw Widget Graphics</existingdrawgraphicslabel>
            <graphicalsearchlabel>Graphical Search</graphicalsearchlabel>
            <textsearchlabel>Text Search</textsearchlabel>
            <resultslabel>Results</resultslabel>
            <layerlabel>Search Layer:</layerlabel>
            <layerfieldlabel>Search Layer Field:</layerfieldlabel>
            <nolayerlabel>No search layer defined.</nolayerlabel>
            <submitlabel>Search</submitlabel>
            <pointlabel>Select by Point</pointlabel>
            <linelabel>Select by Line</linelabel>
            <rectanglelabel>Select by Rectangle</rectanglelabel>
            <polygonlabel>Select by Polygon</polygonlabel>
            <clearlabel>Clear</clearlabel>
            <loadinglabel>Loading...</loadinglabel>
            <selectionlabel>Features Selected:</selectionlabel>
            <gridresultsLabel>Show Results in Grid</gridresultsLabel>
            <csvdefaultname>Selected Records</csvdefaultname>
            <exportbtnlabel>Export</exportbtnlabel>
            <export2csvoptionlabel>Export to CSV</export2csvoptionlabel>
            <export2txtoptionlabel>Export to Txt</export2txtoptionlabel>
            <bufferLabel>apply a search distance:</bufferLabel>
            <spatialsearchLabel>Spatial search</spatialsearchLabel>
            <applybufferlabel>Apply buffer</applybufferlabel>
            <searchlayerlabel>Search entities of:</searchlayerlabel>
      </labels>
      <info>widgets/InfoTemplates/InfoPopupWidget.swf</info>
      <symbols>
      <simplefillsymbol color="0x999999" alpha="0.9">
            <outline color="0xff0000" alpha="0.8" width="2"/>
      </simplefillsymbol>
      <simplemarkersymbol style="circle" size="12" color="0x999999" alpha="0.5" xoffset="0" yoffset="0" angle="0">
            <outline style="solid" color="0x000000" alpha="1" width="1"/>
      </simplemarkersymbol>
      <!--<picturemarkersymbol url="assets/images/i_search.png" height="30" width="30" xoffset="0" yoffset="0"/>-->
            <simplelinesymbol color="0xff0000" alpha="0.8" width="2"/>
    </symbols>
</configuration>
Lei,
   I thought that there might have been a bug with the numberformat when using a joined field like you are, but I just tested that and it work fine for me... What version of the widget are you using?
LeiZhou
We use 2.4 version and did not get a chance to update yet. Thanks!
Lei,
   This was something that was fixed after version 2.4 then. More reason to update to the latest version.
