How to change the basemap of arcgis-viewer-flex-3.4
2271
08-15-2013 05:22 PM
wukongsun
Hello all,
    I am learning the arcgis-viewer-flex-3.4 recently,and i want to know how to change the default basemap.
    I have tried to add <basemap> in the config.xml,but the dafault basemaps were still exist.
    Is there anyone can help?
    Thanks in advance!
AnthonyGiles
Honored Contributor
Wukong,
You have to set the addarcgisbasemaps to false. The following example is set to use a geographic projection:
<map wraparound180="false" initialextent="58.36 28.1 70.36 35.1" fullextent="58.36 28.1 70.36 35.1"  addarcgisbasemaps="false">   <basemaps>     <layer label="Mapping" type="tiled" visible="true" alpha="1" url="http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer" icon="assets/images/Base_Mapping.png" />   </basemaps> </map>
Regards
Anthony
wukongsun
which files are in relation to basemap.
AnthonyGiles
Honored Contributor
Wukong,
Regards
Anthony
wukongsun
Wukong,
  <basemaps>
  </basemaps>
</map>
Regards
Anthony
Yes , this is.
Thank you very much.:cool:
