How do I identify multiple features and and return field values in a form?
1257
7
01-25-2012 08:29 AM
AimeiChen
I am a newbie to flex programming. I am trying to migrate a customized identify widget from 1.3 to 2.4 and stuck with the output of the identify result. The tool works in 1.3 and it identify multiple layers and returns the specified filed values in one form. I attached my source code here, can someone help me please?
Amy
RobertScheitlin__GISP
Amy,
  Why do you have your results in an Accordion when you are only giving it one canvas?
AimeiChen
Amy,
Hi, Robert
I have the accordion with one canvas in flex 1.3, so didn't touch that piece a lot. Is this a problem?
Amy
Amy,
   See if this works. I can not test as your map service is not accessible.
Don't forget to click the top arrow (promote) and to click the Mark as answer check as shown below:
AimeiChen
Amy,
Hi, Robert
Thanks for your quick response. I noticed you modified the accordion to a scroller, but unfortunately it's still not working. the processIdentifyResults function have not been called yet.
Amy
Amy,
   As I mentioned I can not test/debug your code because I don't have access to the map service you are using. You need to check your identifyParams and the URL, identifyParams.tolerance = 1 seems pretty low. Do you get to the Alert in the identifyFeatures function?
AimeiChen
Amy,
Hi, Robert
I changed the tolerance to 3, but the problem actually is in idResult event, once I fixed that, it is working perfectly. Thanks for your help, I'd like to give you a point if you can tell me how to do it?.
Amy
private function idResult(event:ResultEvent):void{
   onResult(new IdentifyEvent("",idResults));
Amy,
    Glad you got it working. Don't forget to click the top arrow (promote) and to click the Mark as answer check as shown below:
