Height of Map
1262
09-26-2011 01:13 PM
ShaunWeston
For seem reason I can't find where to change the code to change the height of the map. If you remove the header there is white space at the top, but I can't change this. Image attached.
Does anyone know where to change this? I thought it would be in the ViewerContainer.mxml.
RobertScheitlin__GISP
Shaun,
   It's actually a main config.xml attribute.
<map initialextent="-14083000 3139000 -10879000 5458000" top="40">
ShaunWeston
Ah! Too easy!
