Hi Jack,I'm having the same issue now of the heatmap being unable to print out in the OOTB print service. May I know if you have managed to get the Alive PDF library to print the heatmap out? If you are able to provide the code for that, it would be great as we're in an urgent state right now.
Hi, I am using the flex viewer 3.6 and I didn�??t find this widget compiled for that version. I did found the widget on the Github, but I don�??t know how to make it work from there, I don�??t know how to compile it. On this link: http://www.arcgis.com/home/item.html?id=43daf0ffb1d34e31ad752da1340aeb40, only found the 3.5 version, which was loaded successfully. So I configured the widget to see my service. When I preview the application it says 0 features contained. I read all threads here checking possible problems and solutions without been able to solve my problem. When I open the application in Internet explorer and moxila, it gave me this error Thank you for the help!Julia
Hi Julia,You can get the latest compiled versions from the releases section on GitHub (https://github.com/Esri/heatmap-widget-flex/releases). I would start with loading the widget into Application Builder and give that a try.
Signed in members can post, follow updates, and more. New here? Register a free account.
