Heat Map on ArcGIS Viewer for Flex
13991
64
03-07-2011 12:04 PM
MESHALALMASHAN
   I'm trying to implement a heat map on my ArcGIS viewer using the code posted on the following link:
http://thunderhead.esri.com/readonlyurl/HeatMapNew/srcview/
But still I'm not getting anything running yet as I'm not sure if it's compatible with the Viewer for Flex or not.
Any idea?
xanderm
LeeAllen
xander       [INDENT]        http://www.arcgis.com/home/item.html...752da1340aeb40   [/INDENT]
I had multiple issues with that link, I was able to implement this though...http://www.arcgis.com/home/item.html?id=94c6b99f7b89496cb95f97394a023c6e
xanderm
hhhmmmm. I had no issue. I just downloaded and deployed this morning.
DanielOchoa
Anyone have luck implimenting the heatmap widget found here:
http://www.arcgis.com/home/item.html?id=43daf0ffb1d34e31ad752da1340aeb40
in the new 2.4 viewer?
~ D
LloydHeberlie
Sample updated to support ArcGIS Viewer for Flex 2.4
ArcGIS Viewer for Flex HeatMapWidget
Sorry about that.
Lloyd
DanielOchoa
I'll plug this in ASAP.  Thanks!
DanielOchoa
Lloyd,
Got it working like a charm! Its a VERY nice widget.
Just one question - the record set I have the widget pointing at has about 30,000 records, yet the widget reports "1000 features contained", even when zoomed out to the entire record set. However, the heat graphics produced seemingly covers the entire dataset and displays correct information, despite the "1000" number. Any explanation for this? Its probably me not understanding something, so any answer would be appreciated.
Thanks again!
~ D
Never mind, answered my own question - but to anyone else who may have the same question I did - remember to change the "Maximum Number of Records Returned By Server" value under "Map Service Properties" to match the amount of data you want this widget to measure.... 😉
JeffreyUtter
I tried updating my application, but got 2 errors:
  <esri_stl:ArcGISHeatMapLayer id="heatMapLayer" url="{m_url}"
One for the heatmaptest and the other for the heatmaptime test mxml
Can anyone help?
Thanks.
MichaelHarvey
Works great.
Question about the heat map time line function.
The residual data does not leave the map as the slider is progressed through the date range.
eg, I have 10 various xy points for 1980, then another various 10 points for 1981, but as I move the slider from 1980 to 1981 I no longer have 10 points only I have a cumulative 20 points and thus the heat spot increases. Is this by design? or can it be changed to only reflect the data as requested by the given date range of the slider request.
Cheers
Mick.
