HeaderController shifting back and forth...
1233
05-05-2011 12:44 PM
JustinRiggs
I modified my HeaderController to shorten it up, but now when I roll over the widget icons, it shifts back and forth from left to right. Is there any way to get it to stay in place?
AlexJones
Can you post the mxml for your HeaderController. Everything in the group tag.
Did you change more than just that file?
JustinRiggs
Alex,
I didn't change anything more than that file. I did figure this out, though (kind of). I just had to fiddle around with the width and height properties of the image I replaced the label with, and at "50" the shifting stopped. Not an optimal solution but looks fine, and works for me.
KarlWilson
I had a similar experience - the width of the widget label was the key, as you've discovered already.
