eDraw Widget Bug - Point coordinates not drawn correctly
2521
05-05-2011 01:49 AM
KarlWilson
I'm seeing some strange behaviour in the eDraw widget. I'm using ArcGIS Viewer for Flex version 2.3.1 and version 2.3 of the eDraw widget.
When I draw a point with the "Show Measurements" option selected, the coordinates do not draw on the screen as they should. When I draw any other shape, the measurement text draws OK.
If I draw a shape first, and then a point, then the point coordinates will appear on top of the measurement text associated with that previous shape.
Also, when I save the graphics layer it clears the drawing from the screen. I'm not sure if this intended or not.
RobertScheitlin__GISP
Karl,
   The save button clearing the graphics has always been the intended behavior. As for the bug you are seeing I will work on this ASAP.
Karl,
   This is now fixed in version 2.3.1 of the eDraw widget.
KarlWilson
I've just tested the new version and it's working great.
Thanks for the quick fix Robert!
