GeoRSS display effects based on attribute values
741
04-13-2011 08:26 AM
Sung-JunKim
All,
I would like to display glow effects on GeoRSS ponits based on attribute values when it's activated.  For example, attribute name is "Status", if 'Status' ="ENRT" or "DISP", then show glow effects on points that have attribute values of ???ENRT??? or ???DISP???.  Where and how can I modify GeoRSS widget source code to reflect this request to be functional?  I am using ArcGIS Viewer for Flex 2.2.
My GeoRSS widget is modified by adding additional attributes to the source code to accommodate different attributes in xml file.  Please see the attached GeoRSS data file for reference.
I appreciate your kind help in advance.
SungJun
