Finding the correct Web Server Base Folder URL - ArcGIS Viewer for Flex
5352
9
02-06-2014 06:27 AM
RichardGeoghegan
When getting started with ArcGIS Viewer for Flex I enter the following details;
Web Server Base Folder: C:\inetpub\wwwroot\flexviewers
Web Server Base Folder URL: my machine name followed by the \flexviewers (can't provide http address here)
However, I receive the following error message;
Please check your Web Server Base Folder URL.
I can't understand why the URL I provided isn't correct.
I am running on Windows 7 and have turned on II 6 Management Capability and Management Console. Is it possible that I need to share the folder on the server and if so how would I go about doing this?
RobertScheitlin__GISP
Richard,
   Are you placing http:// in the front of your machine name?
Here is mine as an example:
http://gislap183/flexviewers
AnthonyGiles
Honored Contributor
Richard,
Try using http://localhost/flexviewers as your base URL
Regards
Anthony
RichardGeoghegan
Richard,
Yes I have included http:// in front of my machine name.
RichardGeoghegan
Richard,
Regards
Anthony
Thanks Anthony I tried this but no luck.
AnthonyGiles
Honored Contributor
Richard,
What do you get if you try hitting the webpage http://localhost from your web browser?
Regards
Anthony
Richard,
   Have you verified that you have IIS or some other web server software installed on your PC?
RichardGeoghegan
Richard,
This must be the problem, I assumed that it was already installed. Thanks Robert.
Richard,
   This is done using the windows installer. Here is a link:
http://www.howtogeek.com/howto/windows-vista/how-to-install-iis-on-windows-vista/
Richard,
   If you have found that these replies have answered your question than please mark this thread as such.
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow these steps as shown in the below graphic:
