eLocateWidget
2070
7
02-10-2014 05:32 AM
ScottEwart
This post is for Robert regarding the eLocateWidget. I am having the issue with find coordinate tool. you asked me to attach my .xml file. Any help would be greatly appreciated.
Scott Ewart
ScottEwart
Robert,
I figured this one out too. I was pointing to the wrong geometry service. thanks for the help. i will close this now.
Scott
RobertScheitlin__GISP
Scott,
   I will be more than happy to help. All I need is for you to attach your eLocateWidget.xml (just zip it up and attach). From the sounds of it your basemaps are in PA state plane? So that means you are not using any esri basemaps right?
ScottEwart
Robert,
I figured out what the problem was. After I entered the coordinates I would just hit the enter key not the locate button. if I use the locate button it works fine. On a different problem. I am getting an error when i use the Enhanced Drawing Widget. When i place a point i get this Error:[FaultEvent fault=[RPC Fault faultString="Security error accessing url" faultCode="Channel.Security.Error" faultDetail="Destination: DefaultHTTP"] messageId="5F5D0629-5D7F-89D8-1019-1D59D27E7D3D" type="fault" bubbles=false cancelable=true eventPhase=2]. Any help would be appreciated.
Scott
Scott,
   A channel security error means that you have a crossdomain.xml issue.
ScottEwart
Robert,
Scott
Scott,
   Do you have your main config.xml set to your own geometry service on the same server that your data located?
Scott,
   Glad you got it figured out. Based on your first error I was able to find an issue when using the enter key after inputing DMS coorinates and that will be fixed in the next release.
ScottEwart
Robert,
That would be great.
We use all your apps. Thanks for the great work.
Scott
