Excludeing Sublayers
724
03-22-2011 05:11 AM
ChrisMarsh
Is it possible to exclude sublayers? Using the excludelayer tag in the Mapswitcher widget I can only exlcude the whole operational layer. Any help would be greatly appreciated.
Thanks
JonFisher
You can set the visibility of sublayers using the layer tag's visiblelayers attribute:
http://help.arcgis.com/en/webapps/flexviewer/help/layer_tag.htm
You can exclude sublayers from the table of contents using Robert Scheitlin's TOC widget:
http://www.arcgis.com/home/item.html?id=e2cb71d5c04d40d19e9f945ae0db7ce8
ChrisMarsh
I tried the visbile layers and it just checked or unchecked the data, so I will try that widget.
Thank you,
Chris
