eSearch Limits
1003
04-24-2012 10:47 AM
jamesdiaz
Does anyone know the limits of eSeach? will it search feature classes with over 120K records?
RobertScheitlin__GISP
James,
   If for some God awful reason you have set you ArcGIS server to return 120K records than the widget should work. There is a reason that esri sets the default limit on Map Service to return 1000 records though, and it is because of performance.
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote) as shown below:
James,
jamesdiaz
Robert thanks for the quick response!
