eSearch (3.0)- Disable InfoWindow popups
3058
10
11-13-2012 09:36 AM
JasonStanton__GISP
I am wondering if anyone knows how to disable InfoWindow popups from the initial search results AND fixed data grid.  I commented out the mouseOverSearchResult from the eSearchWidget.mxml and that worked for the initial search results but they still appear when I 'mouse over' the results in the fixed data grid.
Any assistance would be greatly appreciated!
RobertScheitlin__GISP
Jason,
   In the SearchWidgetFixedDG.mxml search for this string "showInfoWindow" and every where you find that called (i.e. timerTick2 function and clickRow function) comment out those lines.
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow these steps as shown in the below graphic:
Jason,
   What is your reasoning for wanting them disabled? I am just about to release 3.0.14 that fixes some popup issues.
MegPeterson
RhettZufelt
MVP Notable Contributor
JasonStanton__GISP
Robert,
First- Thank you so much for all of your EXCELLENT widgets and support on the forums...they have been INVALUABLE resources to me (I'm a 'GIS Guy' who has been thrust into the 'developers' world without a life jacket).
Essentially I want to disable the popups because one of our communities asked for that specifically.  They find it to be 'overkill' when the results already come up in the search interface and on the data grid.
I will look into the above suggestions (thank you Meg and rzufelt) to see if those will help me, but often times i don't really know what I'm looking at.
Thanks to all again for your assistance!!
Jason
Jason,
   OK, I would advise you to hold off till latter this week as I have added the ability to disable popups to the widget in version 3.0.14.
JasonStanton__GISP
OK, so I tried the suggestions above and I must have missed something.  I have commented out every "infoWindow", "showHighlight" and "showStateResults" reference from both the "eSearchWidget.mxml" and "SearchWidgetFixedDG.mxml".  When i 'mouse over' results in the Fixed DG the popup info window still appears.
Any thoughts?
JasonStanton__GISP
Robert,
I just saw your updated post.  THANK YOU SO MUCH!!  I VERY MUCH appreciate your assistance!!
Jason,
JasonStanton__GISP
Robert,
I upgraded to the latest version (I think I was on 3.0.9) and your answer worked!  THANK YOU SO MUCH!!
