Error in printing from the default print widget
991
02-04-2013 11:06 AM
JasonHarshman
I'm getting an error when I try to print from our 3.1 Flexviewer using the default print widget. It uses the Esri GP toolhttp://sampleserver6.arcgisonline.com/ArcGIS/rest/services/Utilities/PrintingTools/GPServer/Export%2....
The error only happens when I turn layers on or off. Below is the error I receive:
Error executing print task:
[RPC Fault faultString="HTTP request error" faultCode="Server.Error.Request" faultDetail="Error: [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2032"]. URL: http://sampleserver6.arcgisonline.com/ArcGIS/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%20Map%20Task/execute"]
JasonHarshman
It appears the print GPServer setup by Esri is limited to 1,000 features, which I believe is the default. We don't have ArcServer so we can't setup our own print service. We do have AGO, but to my knowledge, you cannot publish a GP service through AGO.
