eSearch data grid question
1221
02-12-2013 09:20 AM
MattPohl
Here is the situation I have for one of my Viewer's. I have the eSearch widget acting as two separate tools; each controlling a separate operational layer. I realize I can have all layers in one widget, but have set it up this way for reasons that I won't try to explain on this post. What I am trying to accomplish is that once a search is performed a fixed data grid will appear for just one of the widgets. ie: if a search is performed using eSearch widget A, the results will appear in a fixed data grid. If a search is performed in eSearch widget B, no data grid will appear.
I have tried setting <autoopendatagrid/> to false and have also added datagrid to <disablebuttons> for eSearch widget B, but when a do a search the datagrid still appears. Is this possible to do? Any help on this would be greatly appreciated.
Matt
RobertScheitlin__GISP
Matt,
   What you are wanting is not currently possible though configuration.
Matt,
MattPohl
Understood Robert, thanks for the reply. Do you see this as something that might be configurable down the road?
Matt
Matt,
   It sounds reasonable that the autoopendatagrid should control the fixed datagrid similarly to the way it does the float datagrid. So yes it should be fixed in the next version.
MattPohl
Great, thanks Robert
Matt
