Enhanced Search Widget problem
3187
6
06-26-2013 05:17 AM
JamesEdge
I am using eSearch (version 3.2.3) to find and zoom to a polyline. This polyline is highlighted red against all the other blue lines. When I print/save the map using ExportWebMapTask the polyline is not red but is a turquoise color (see attachment) for all format types jpg/pdf etc. I have downloaded and created a 3.3 version of this viewer and the same thing happens with it. If I use the Identify widget to select and highlight (red) a polyline and then print/save it works ok. Any help is appreciated. Thanks.
AdamMcArthur2
I am having the same problem as well. When something is highlighted via the enhanced search widget (like a polygon), the fill is suppose to print as transparent.
However, when I print to ArcGIS Server 10.1, the fill is a turquoise with no transparency.
Haven't found a solution yet.
RobertScheitlin__GISP
Guys,
    This is an issue I have brought up with the Flex API Team. but I am thinking it is actually a ArcGIS Server issue.
BrentFoster
Running into the same issue if I print out point results as well..
Yep, it does not matter what geometry type it is as it seems to be a server issue with featureLayers.
JayHalligan
Any resolution for this yet?
Guys,
   This issue was reported to the server print guys and they think it is something they should be able to fix but as it is a server issue it will not be addressed untill another server service pack of server version is released.
