Noticing some odd behaviour when using the select by rectangle tool. After the initial selection is made (on a parcel layer) clicking anywhere else on the map will create a new selection without being prompted to draw a new rectangle. This should work the same way as the select by polygon tool - after the initial selection if yo click elsewhere you must redraw a new polygon to create a new selection.
Also, when closing the tool the selection is cleared, but the buffer remains...
And...when drawing a rectangle there is a tooltip 'Press down to start and let go to finish' that hangs around even if after you select to do a text search...
Questions on the Enhanced Search Widget... Can I change the name of the widget in the config file or does it break the url search function? Also, is it possible to change "search" in the URL to "SEARCH" if I am using the uncompiled version to save me the headache of changing a bunch of links on an outside site that hits the viewer? I am currently making the jump from an older version of your esearch widget (2.2.10 I think) to the latest version. Thanks!
