Emily,
Nope... Not currently but this seems like a good Idea I will add it to the wish list.
how to I remove the search widget icon that appears on the upper left-hand side of the windowThat icon is part of the widget template and once again would require a lot to change. Even if you remove the icon attribute from the widget in the main config.xml it will just use the default widget icon.
<linkfield linkprefix="http://www.septicsearch.com/pump/AttachedResults.aspx?&srch=" linksuffix="">WebData.DBO.SiteAddresses.ParcelID</linkfield>
Justin,
See if changing to this works:<linkfield linkprefix="http://www.septicsearch.com/pump/AttachedResults.aspx?&srch=" linksuffix="">WebData.DBO.SiteAddresses.ParcelID</linkfield>
