Enhanced Search Widget - Domains
5427
25
09-21-2012 08:40 AM
AndrewMilanes
I can't seem to figure out the correct expression syntax for using a domain.  Here's what I have, which isn't working:
        <layer>
            <definitionexpression/>
            <enableexport>true</enableexport>
            <name>Field Boom</name>
            <url>http://webmaps.es2-inc.com:6080/arcgis/rest/services/dfm_fs/Group_Response_Assets/FeatureServer/5</url>
            <expressions>
                <expression alias="Boom Type" textsearchlabel="Seach for Boom Type:" isvaluerequired="false">
                    <values>
                        <value prompt="Select boom type" usedomain="true" field name="TYPE">TYPE = '[value]'</value>
                    </values>
            </expressions>
            <graphicalsearchlabel>Use one of the graphical search tools to select Boom</graphicalsearchlabel>
            <spatialsearchlayer>true</spatialsearchlayer>
            <titlefield>TYPE</titlefield>
            <fields all="true"/>
            <links/>
            <zoomscale usegeometry="true" zoompercent="2"/>
            <autoopendatagrid>false</autoopendatagrid>
            <queryattachments>false</queryattachments>
            <relates/>
            <symbology>
                <simplefillsymbol color="0x0000ff" alpha="0.5">
                    <outline color="0x00ffff" alpha="0.8" width="2"/>
                </simplefillsymbol>
            </symbology>
        </layer>
RobertScheitlin__GISP
Andrew,
   I am not sure where the extra name in this line came from:
but it should be:
<value prompt="Select boom type" usedomain="true" field="TYPE">TYPE = '[value]'</value>
as shown in the documentation.
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow the steps as shown in the below graphic:
AndrewMilanes
I've tried with or without "name"
I get TypeError 1085
Andrew,
   Is your domain for the field TYPE listed in your REST Service Directory for that layer?
AndrewMilanes
ArcGIS REST Services Directory  Logged in user : xxxxxxx | Logout | Get Token
Home > services > dfm_fs > Group_Response_Assets (FeatureServer) > Boom Help | API Reference
JSON
Layer: Boom (ID: 5)
View In:   ArcGIS.com Map
Display Field: CREATE_NAME
Type: Feature Layer
Geometry Type: esriGeometryPolyline
Description:
Definition Expression: N/A
Copyright Text:
Default Visibility: true
MaxRecordCount: 1000
Supported Query Formats: JSON, AMF
Min Scale: 144449
Max Scale: 0
Supports Advanced Queries: true
Supports Statistics: true
Extent:
XMin: -1.01409911345E7
YMin: 1226528.0568000004
XMax: -8321822.6392
YMax: 3563877.202799998
Spatial Reference: 102100  (3857)
Drawing Info:
Renderer:
Unique Value Renderer:
Field 1: TYPE
Field 2: null
Field 3: null
Field Delimiter: ,
Default Symbol:
N/A
Default Label: null
UniqueValueInfos:
Value: 1
Label: containment
Description:
Symbol:
Style: esriSLSSolid
Color: [255, 170, 0, 255]
Width: 3
Value: 2
Label: sorbent
Description:
Symbol:
Style: esriSLSSolid
Color: [225, 225, 225, 255]
Width: 3
Transparency: 0
Labeling Info:
HasZ: false
HasM: false
Has Attachments: true
HTML Popup Type: esriServerHTMLPopupTypeAsHTMLText
Type ID Field: TYPE
Fields:
OBJECTID ( type: esriFieldTypeOID , alias: OBJECTID , editable: false , nullable: false )
TYPE ( type: esriFieldTypeInteger , alias: Boom Type , editable: true , nullable: true )
SIZE ( type: esriFieldTypeString , alias: Size , editable: true , nullable: true , length: 50 )
SECTION_LENGTH ( type: esriFieldTypeInteger , alias: Section Length , editable: true , nullable: true )
NUMBER_SECTIONS ( type: esriFieldTypeSmallInteger , alias: Number of Boom Sections , editable: true , nullable: true )
COMMENTS ( type: esriFieldTypeString , alias: Comments , editable: true , nullable: true , length: 254 )
CREATE_NAME ( type: esriFieldTypeString , alias: Added By , editable: false , nullable: true , length: 50 )
CREATE_DATE ( type: esriFieldTypeDate , alias: Date Added , editable: false , nullable: true , length: 36 )
EDIT_NAME ( type: esriFieldTypeString , alias: Edited By , editable: false , nullable: true , length: 50 )
EDIT_DATE ( type: esriFieldTypeDate , alias: Date Edited , editable: false , nullable: true , length: 36 )
GlobalID ( type: esriFieldTypeGlobalID , alias: GlobalID , editable: false , nullable: false , length: 38 )
Types:
Domains:
SIZE:
Coded Values: [10" 12" 12" 18" 18" 24" 24" 36" 36" 48" 48": 10"] , [12": 12"] , [18": 18"] , ...3 more...
SECTION_LENGTH:
Coded Values: [50: 50'] , [100: 100']
Templates:
Description:
Prototype:
TYPE: 1
SECTION_LENGTH: 50
NUMBER_SECTIONS: 1
Drawing Tool: esriFeatureEditToolLine
Domains:
SIZE:
Coded Values: [5": 5"] , [8": 8"]
SECTION_LENGTH:
Coded Values: [10: 10']
Templates:
Description:
Prototype:
TYPE: 2
SECTION_LENGTH: 10
NUMBER_SECTIONS: 4
Capabilities: Query,Create,Update,Delete,Uploads,Editing
Sync Can Return Changes: true
Is Data Versioned: true
Supports Rollback On Failure: false
Edit Fields Info:
Creation Date Field: CREATE_DATE
Creator Field: CREATE_NAME
Edit Date Field: EDIT_DATE
Editor Field: EDIT_NAME
Supported Operations:   Query   Apply Edits   Add Features   Update Features   Delete Features   Generate Renderer   Return Updates
Andrew,
  Hmm... I am missing where the TYPE field is associated with a particular domain in those sub types... What does your REST Directory look like for this layer using the Map Server instead of the Feature Server?
AndrewMilanes
ArcGIS REST Services Directory  Logged in user : xxxxx | Logout | Get Token
Home > services > dfm_fs > Group_Response_Assets (MapServer) > Boom Help | API Reference
JSON
Layer: Boom (ID: 5)
Type: Feature Layer
Description:
Copyright Text:
Min Scale: 144449
Max Scale: 0
Has Labels: false
Can Modify Layer: false
Can Scale Symbols: false
Extent:
XMax: -8321822.6392
Drawing Info:
Renderer:
Field 1: TYPE
Field 2: null
Field 3: null
Field Delimiter: ,
Default Symbol:
N/A
Default Label: null
UniqueValueInfos:
Value: 1
Label: containment
Description:
Symbol:
Style: esriSLSSolid
Width: 3
Value: 2
Label: sorbent
Description:
Symbol:
Style: esriSLSSolid
Width: 3
Transparency: 0
Labeling Info:
HasZ: false
HasM: false
Type ID Field: TYPE
Fields:
OBJECTID ( type: esriFieldTypeOID , alias: OBJECTID )
TYPE ( type: esriFieldTypeInteger , alias: Boom Type )
SHAPE ( type: esriFieldTypeGeometry , alias: SHAPE )
SIZE ( type: esriFieldTypeString , alias: Size , length: 50 )
SECTION_LENGTH ( type: esriFieldTypeInteger , alias: Section Length )
NUMBER_SECTIONS ( type: esriFieldTypeSmallInteger , alias: Number of Boom Sections )
COMMENTS ( type: esriFieldTypeString , alias: Comments , length: 254 )
CREATE_NAME ( type: esriFieldTypeString , alias: Added By , length: 50 )
CREATE_DATE ( type: esriFieldTypeDate , alias: Date Added , length: 36 )
EDIT_NAME ( type: esriFieldTypeString , alias: Edited By , length: 50 )
EDIT_DATE ( type: esriFieldTypeDate , alias: Date Edited , length: 36 )
GlobalID ( type: esriFieldTypeGlobalID , alias: GlobalID , length: 38 )
SHAPE.len ( type: esriFieldTypeDouble , alias: SHAPE.len )
Types:
Domains:
SIZE:
SECTION_LENGTH:
Domains:
SIZE:
SECTION_LENGTH:
Supported Operations:   Query   Generate Renderer   Return Updates
AndrewMilanes
Actually, now that I'm looking at it.  TYPE has sub-types, not a domain.  How would I use that?
Andrew,
   Subtypes will be supported as the source for the eSearch drop down in the next version 3.0.10 due out this week.
Andrew,
   Version 3.0.10 now available
