Enhanced Search Widget - Domains
5514
25
09-21-2012 08:40 AM
AndrewMilanes
I can't seem to figure out the correct expression syntax for using a domain.  Here's what I have, which isn't working:
        <layer>
            <definitionexpression/>
            <enableexport>true</enableexport>
            <name>Field Boom</name>
            <url>http://webmaps.es2-inc.com:6080/arcgis/rest/services/dfm_fs/Group_Response_Assets/FeatureServer/5</url>
            <expressions>
                <expression alias="Boom Type" textsearchlabel="Seach for Boom Type:" isvaluerequired="false">
                    <values>
                        <value prompt="Select boom type" usedomain="true" field name="TYPE">TYPE = '[value]'</value>
                    </values>
            </expressions>
            <graphicalsearchlabel>Use one of the graphical search tools to select Boom</graphicalsearchlabel>
            <spatialsearchlayer>true</spatialsearchlayer>
            <titlefield>TYPE</titlefield>
            <fields all="true"/>
            <links/>
            <zoomscale usegeometry="true" zoompercent="2"/>
            <autoopendatagrid>false</autoopendatagrid>
            <queryattachments>false</queryattachments>
            <relates/>
            <symbology>
                <simplefillsymbol color="0x0000ff" alpha="0.5">
                    <outline color="0x00ffff" alpha="0.8" width="2"/>
                </simplefillsymbol>
            </symbology>
        </layer>
RhettZufelt
MVP Notable Contributor
Does this widget support the subtypes on a FeatureService?  didn't see anything about it in the documentation, but all the examples are against MapService.
Just a thought,
R_
RobertScheitlin__GISP
Rhett,
   I have never tested it specifically on a FeatureService. Have you tested and it does not work or something?
RhettZufelt
No, have not had time to set up data with sub type, yet alone featureservice.
I just noticed in David's code that he is searching against FeatureServer/5.
Thought maybe that might be his issue.
R_
Rhett,
  Ahh... Good catch.
David,
   That might be worth a try. Change FeatureServer to MapServer.
<url>http://webmaps.es2-inc.com:6080/arcgis/rest/services/dfm_fs/Group_Response_Assets/MapServer/5</url>
DavidAlford1
The offer still stands!! Anyone that wants to help us write or modify widgets for our company and will pays for your time, please send me an email @ [email protected].
Scott_Russell
Andrew,
   I am not sure where the extra name in this line came from:
but it should be:
<value prompt="Select boom type" usedomain="true" field="TYPE">TYPE = '[value]'</value>
as shown in the documentation.
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow the steps as shown in the below graphic:
Its actually not expressed in the documentation.  You mention it but its not sampled anywhere.
